Reach RS4 Pro
All-band RTK GNSS receiver with dual cameras for AR stakeout and capturing hard-to-reach points.
€3.999
- SHIPPING IN LATE DECEMBER
Survey Kit
Emlid Base and Rover Kit
A powerful RTK set: the Reach RS4 base and the Reach RS4 Pro rover.
€7.355
Two Full-HD cameras
AR guidance for stakeout Measurements from images
High precision
RTK: 7 mm + 1 ppm
Tilt compensation: RTK: 2 mm + 0.3 mm/° -
Base and rover
915 MHz LoRa
450 MHz UHF
NTRIP
- SHIPPING IN LATE NOVEMBER
Scanning KIT
Pix4D & Emlid Scanning Kit
Mobile terrestrial scanning solution with RTK accuracy
€3.900
Hardware:
✓ Reach RX2
✓ Emlid Handle
✓ Carrying bag -
Software:
✓ PIX4Dcatch
- In Stock
Survey Kit
Reach RS3 Survey Kit
Two Reach RS3 for use as a base and rover
€4.998
IMU tilt compensation
Accurate results even with large tilt angles
NTRIP and RTCM3
Supported protocols to send and receive corrections
Dual-band radio
868/915 MHz LoRa to receive and transmit corrections
450 MHz UHF to receive corrections
Unmanned Kit
Reach M2 Unmanned
Systems Kit
Multi-band RTK kit for precise navigation and mapping with unmanned systems.
Base and rover
Enable RTK or PPK with Reach RS3 base and Reach M2 onboard module.
Centimeter-accurate positioning
Output precise coordinates to the autopilot or collect coordinates for photos.
NMEA or RINEX
Supports industry-standard data protocols.
Emlid – Field Ready GNSS Receivers
A compact and lightweight RTK rover designed for simplified and precise data collection and stakeout, even when using a tilted pole.
Reach RS3
Versatile and reliable, the Reach RS3 can function as both a base or a rover across multiple surveying techniques, including RTK, PPK, and PPP. It’s especially well-suited as a base station for RTK drones from DJI, Autel, Wingtra, and other brands.
Reach RS4 and Reach RS4 Pro
Emlid’s flagship receivers, the Reach RS4 and RS4 Pro, deliver reliable precision in any surveying environment thanks to their state-of-the-art antenna and tilt compensation. These receivers provide maximum flexibility by operating as a base or rover and supporting RTK corrections via NTRIP, LoRa, or UHF radio.
The reach RS4 Pro also features a dual-camera system, enabling AR stakeout and accurate measurements directly from images.
Reach M2
To equip your UAV with RTK drone mapping capabilities, use the Emlid GNSS module Reach M2. Connect it to your drone for RTK or PPK aerial surveying and capture precise geospatial data.
Online Store and Local Dealers
You can purchase Emlid products either online in our online shop or from official dealers. Visit the list of dealers to find the desired product and see if it is available in your country or nearby.
In Emlid online store you can find
- Affordable and easy-to-use RTK receivers with up to a cm precision and high accuracy
- Various accessories for a comfortable and accurate survey
Payment and shipping
For online orders we accept PayPal and card payments. For more details on payment and shipping specifics see the delivery and payment page.
