Reach RS4 Pro
Reach RS4 Pro
All-band RTK GNSS receiver with dual cameras for AR stakeout and capturing hard-to-reach points.
€3.999
Emlid Base and Rover Kit
  • SHIPPING IN MID-January
Survey Kit
A powerful RTK set: the Reach RS4 base and the Reach RS4 Pro rover.
€7.355
  • Two Full-HD cameras
    AR guidance for stakeout Measurements from images
  • High precision
    RTK: 7 mm + 1 ppm
    Tilt compensation: RTK: 2 mm + 0.3 mm/°
  • Base and rover
    915 MHz LoRa
    450 MHz UHF
    NTRIP
Reach RS4
Reach RS4
All-band RTK GNSS receiver: the ultimate precision, even in the most challenging scenarios.
€3.299
Compact rover with all-band RTK
and tilt compensation.
€1.999
Pix4D & Emlid Scanning Kit
  • SHIPPING IN late DECEMBER
Scanning KIT
Mobile terrestrial scanning solution with RTK accuracy
€3.900
  • Hardware:
    ✓ Reach RX2
    ✓ Emlid Handle
    ✓ Carrying bag
  • Software:
    ✓ PIX4Dcatch
Reach RS3
Reach RS3
Multi-band RTK GNSS receiver with tilt compensation
€2.499
Reach RS3 Survey Kit
  • In Stock
Survey Kit
Two Reach RS3 for use as a base and rover
€4.998
  • IMU tilt compensation
    Accurate results even with large tilt angles
  • NTRIP and RTCM3
    Supported protocols to send and receive corrections
  • Dual-band radio
    868/915 MHz LoRa to receive and transmit corrections
    450 MHz UHF to receive corrections
Reach M2
Module
Reach M2
Multi-band RTK GNSS module for precise navigation and UAV mapping
€649
Reach M2 Unmanned
Systems Kit
  • In stock
Unmanned Kit
Reach M2 Unmanned
Systems Kit
Multi-band RTK kit for precise navigation and mapping with unmanned systems.
€3.635
  • Base and rover
    Enable RTK or PPK with Reach RS3 base and Reach M2 onboard module.
  • Centimeter-accurate positioning
    Output precise coordinates to the autopilot or collect coordinates for photos.
  • NMEA or RINEX
    Supports industry-standard data protocols.
Emlid – Field Ready GNSS Receivers
A compact and lightweight RTK rover designed for simplified and precise data collection and stakeout, even when using a tilted pole.
Reach RS3
Versatile and reliable, the Reach RS3 can function as both a base or a rover across multiple surveying techniques, including RTK, PPK, and PPP. It’s especially well-suited as a base station for RTK drones from DJI, Autel, Wingtra, and other brands.
Reach RS4 and Reach RS4 Pro
Emlid’s flagship receivers, the Reach RS4 and RS4 Pro, deliver reliable precision in any surveying environment thanks to their state-of-the-art antenna and tilt compensation. These receivers provide maximum flexibility by operating as a base or rover and supporting RTK corrections via NTRIP, LoRa, or UHF radio.
The reach RS4 Pro also features a dual-camera system, enabling AR stakeout and accurate measurements directly from images.
Reach M2
To equip your UAV with RTK drone mapping capabilities, use the Emlid GNSS module Reach M2. Connect it to your drone for RTK or PPK aerial surveying and capture precise geospatial data.
Online Store and Local Dealers
You can purchase Emlid products either online in our online shop or from official dealers. Visit the list of dealers to find the desired product and see if it is available in your country or nearby.
In Emlid online store you can find
  • Affordable and easy-to-use RTK receivers with up to a cm precision and high accuracy
  • Various accessories for a comfortable and accurate survey
Payment and shipping
For online orders we accept PayPal and card payments. For more details on payment and shipping specifics see the delivery and payment page.
